BME.h
jun1
Please kindly advise.
Application Note AN 4838 How to Use Bit-band and BME on the KE04 and KE06 Subfamilies.
https://www.nxp.com/docs/en/application-note/AN4838.pdf
It is written that "BME.h" is attached in "3.5 BME Library".
How can I get this BME.h?
Please give me the file.
Thank you.
jun
Omar_Anguiano
Hello jun yamada‌
You can find the header at this link FRDM-KE04Z|Freedom Development Platform|Kinetis® MCU | NXP .
The header is contained in "FRDM-KEXX Driver Library Package" file.
Please let me know if this helps
Omar
Omar_Anguiano
Hello jun yamada‌
Omar
jun1
Thank you very much.
I was able to find the file.
It is OK to see the contents.
