Is there a SVD-File available for KL28Z512 micro?
2,120 次查看
milomirbojovic
Hello together,
I am using KL28Z512 micro for my application. While debugging my application I want to use the EmbSysRegister view but I can't find appropriate micro in the settings.
Is there a SVD-File available for this micro?
My IDE is KDS3.2.0 with self created SDK2.2.
Thanks in advance for your support.
Best Regards
Milomir
1,912 次查看
IvanRuiz
Please refer to the following document: https://community.nxp.com/docs/DOC-334307
Ivan.
1,913 次查看
IvanRuiz
Ivan.
1,912 次查看
milomirbojovic
Hello Ivan,
thank you for your answer, but I can´t open the document-link (message: This place or content does not exist or access to it is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.).
Could you please check your link.
best regards
Milomir
