Is there a SVD-File available for KL28Z512 micro?
2,119件の閲覧回数
milomirbojovic
Hello together,
I am using KL28Z512 micro for my application. While debugging my application I want to use the EmbSysRegister view but I can't find appropriate micro in the settings.
Is there a SVD-File available for this micro?
My IDE is KDS3.2.0 with self created SDK2.2.
Thanks in advance for your support.
Best Regards
Milomir
1,911件の閲覧回数
IvanRuiz
Please refer to the following document: https://community.nxp.com/docs/DOC-334307
Ivan.
2 返答(返信)
1,912件の閲覧回数
IvanRuiz
Ivan.
1,911件の閲覧回数
milomirbojovic
Hello Ivan,
thank you for your answer, but I can´t open the document-link (message: This place or content does not exist or access to it is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.).
Could you please check your link.
best regards
Milomir
