IAR K10 Flash config
2,304 次查看
dianel_cheng
   As the attached picture ,  I use IAR to debug MK10DX256ZVLQ10,but  i find there don't have 256K flash config to choose.
  And my IAR version is 6.50.5.  looking forward your help, thanks
标签 (1)
标记 (2)
2 回复数
2,123 次查看
Monica
Senior Contributor III
Hello wuxichengxv,
was that suggestion helpful? Please don't forget to keep us posted :smileywink:
Monica
2,123 次查看
chris_brown
I believe you should be using the FlashK60Dxxx64.board file.  IAR distinguishes the different parts by the amount of SRAM the part has, which is 1/4 the flash size of the part.
Hope this helps,
Chris
