IAR,Error[Li005]: no definition for "__VECTOR_RAM"
4,696 次查看
710787859
I'm coding。IC is MKE02Z64 and IDE is IAR. There are three link errors and i can't deal with them. What should i do?
Error[Li005]: no definition for "__VECTOR_TABLE"
Error[Li005]: no definition for __VECTOR_RAM"
Error[Li005]: no definition for "__BOOT_STACK_ADDRESS"
4 回复数
3,751 次查看
danielchen
Could you let me know your SDK version and IAR version?
If you are using SDK 2.4, then you need to upgrade your IAR to version 8.22.
Please check the release note for more details
3,751 次查看
710787859
My IAR version is 8.22. I don't use SDK and just copy startup files from FRDM-KE02 to my new project.
I don't find the definition of "__VECTOR_TABLE","__VECTOR_RAM", "__BOOT_STACK_ADDRESS".
3,751 次查看
danielchen
Hi Baode
Addresses for VECTOR_TABLE and VECTOR_RAM  and __BOOT_STACK_ADDRESS come from the linker file,  I would suggest you check your linker file.
3,751 次查看
710787859
Hi Daniel,
I have checked my linker file. There is no problem. And I open the linker file and can't find the definitions. Is this a bug of IAR8.22? could you give me a KE02 project based on IAR8.22?
