I2C Slave Loader - Video
1,878 次查看
mjbcswitzerland
Specialist V
Hi All
Note that I2C slave loading is now supported in the uTasker serial loader: http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.pdf
and a video is available showing it in operation, where a KL02 (with small I2C slave loader installed) is updated by a FRDM-K64F board acting as master, and carrying an image of the slave's application firmware: https://youtu.be/awREsqeCEzQ
- The slave loader is included in the serial loader project and operates on all Kinetis parts.
- The master loader operation is included in the uTasker application and so can be immediately used as loader station for production programming without needing any special I2C PC adapters.
Mark
标记 (2)
1,718 次查看
kerryzhou
Thanks a lot for Mark's sharing.
Kerry
