How to use the PIT on the TWR-K60F120
949件の閲覧回数
minminzhengzhen
hello
I am learning the PIT, but there is a problem.The program is built and debug successfully. When the program is running but it cann't get into the Interrupt callback function.1.png2.png3.png
3 返答(返信)
847件の閲覧回数
Robin_Shen
I am not sure if this problem is solved after configure NVIC.
Please let us know if you fixed the issue.
Robin
847件の閲覧回数
minminzhengzhen
OK, I have solved the problem, Thanks.
847件の閲覧回数
mjbcswitzerland
Specialist V
Hi Minmin
Attached is the PIT driver from the uTasker project (for all processor types).
You can get the project at the links below, which allows you to test the PITs (and their interrupts) in its simulator.
Mark
PITs and other HW timers: http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
http://www.utasker.com/kinetis.html
http://www.utasker.com/kinetis/TWR-K60F120M.html
