I am not sure if this problem is solved after configure NVIC.
Please let us know if you fixed the issue.
Robin
OK, I have solved the problem, Thanks.
Hi Minmin
Attached is the PIT driver from the uTasker project (for all processor types).
You can get the project at the links below, which allows you to test the PITs (and their interrupts) in its simulator.
Mark
PITs and other HW timers: http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
http://www.utasker.com/kinetis.html
http://www.utasker.com/kinetis/TWR-K60F120M.html
