Hello friends,
I'm trying boot ucLinux to our TWR-K70F120M Rev 1 boards. I can successfully compile kernel and u-boots but. When i flashing u-boot to integrated flash, i see nand blocking errors. This errors cant seen from emcraft u-boot 1.3.2 tags release.
Are the differences between revisions a reason for not using nand flash?. u-boot 1.3.2 version can load linux images successfully without nand flash load support. I guess after u-boot releases was designed for TWR-K70F120M Rev C. What can i do? Thanks.
So this must be different problem.
From what I know, there has no much difference between the Rev A and Rev C of the TWR-K70F120M. All the difference between the Revs had been listed on the first page of the schematic.
