I wold like to know how to debug FRDM-KW38 EVK with an external debugger.
I search for a guide. But didn't get any result.
Anyone please help
Best Regards
Nidhin
解決済! 解決策の投稿を見る。
Hi @nidhintomy,
Yes, your understanding is correct.
I hope you find this helpful!
Best regards, Julian.
Hi @nidhintomy,
The KW38 can be externally debugged by using MCU-Link Debug Probe (or MCU-Link Pro Debug Probe) and connecting through the SWD connectors.
For a general guide, please take a look into the Getting Started for the MCU-Link, installing the firmware and connecting it to MCUXpresso.
For more information about the OpenSDA serial and debug, please look into chapter 2.3 (OpenSDA serial and debug) of the FRDM-KW38's User's Guide, which can be found under "Documentation" in its page (Freedom Development Kit for KW39/38/37 MCUs).
It is also needed to cut the trace at the bottom of the PCB that connects J15 Pin 2 to J12 Pin 4. This will disconnect the SWD_CLK pin to the KW38 so that it will not interfere with the communications to an offboard MCU connected to J15.
If any other doubt comes up, do not hesitate to ask. I hope you find this helpful!
Best regards, Julián
Hi @nidhintomy,
Yes, PEMicro supports the KW38. You can look into this guide to get started with debugging with PEMicro devices and tools in MCUXpresso.
I hope you find this helpful! Don't hesitate to ask if any other doubts come up!
Now my understanding is with this hardware setup and the guide we can debug FRDM-KW38 with PEMicro.
Is my understanding right ?
Thank you for your support.
Nidhin
Hi @nidhintomy,
