How to use KEA128 UART port as bootloader?
1143291277
 I want to know is there any example of hardware circuit design that using UART port of S9KEAZ128 chip as bootloader? I found the AN5400.pdf from the NXP website, but there's no hardware circuit examples. Can you help me? Thanks so much!
jingpan
Please download from this link https://community.nxp.com/message/1087467?commentID=1087467#comment-1087467
Jing
1143291277
Hi Jing Pan,
Thanks so much, but this link still only have AN5400 and that didn't solve my problem. I want some examples of the hardware circuit about the bootloader using the uart port. Anyway thanks a lot!
jingpan
There is no special circuit that UART need, just three signal, TX,RX,GND. You can buy a USB-serial adaptor to connect your PC with KEA. If you have no hardware design experience, you can refer to FRDM-KEA128 board. NXP Freedom Development Platform for Ultra Reliable Kinetis EA Series MCUs | NXP
It use openSDA to debug KEA. OpenSDA has a virtual UART channel which connect to KEA UART port.
Jing
1143291277
thanks a lot! I got it
