KEA-128 BOOTLOADER
KEA-128 BOOTLOADER
ümitgün
Hello
I am trying to do bootloader for kea-128 series. I found https://community.nxp.com/thread/459210 this post. This code its working fine when you are using first time to bootloader but when i try to update my code in flash I couldn't connect to device. How can i solved my problem?  or I am trying to find KEA-128 series bootloader code example for Kinetis Design Studio project any answer can help me.
Thank you for answer.
Tags (2)
miduo
Actually we had provide the UART Bootloader for KEA family with an application note. See here:
https://www.nxp.com/docs/en/application-note/AN5400.pdf
And the code also provide as:https://www.nxp.com/docs/en/application-note-software/AN5400SW.zip
miduo
ümitgün
I did not see this post i will look this project. Thanks a lot.
