How to remove bootloader mode in FRDM-KL25Z
1,685 次查看
balusting
FRDM-KL25Z opening in bootloader mode. How to open it in frdm-kl25 mode so that i can run my projects . Tried copying .sda ,, but no success please help...
1,471 次查看
Hui_Ma
Please check below link and download OpenSDA firmware there:
http://www.pemicro.com/opensda/index.cfm
Then you need to refer OpenSDA user guide section 2.1 to let OpenSDA enter into bootloader mode, then Drag/drop or copy/paste <DEBUG-APP_Pemicro_v108.SDA> file.
After that unplug the USB cable and plug it in again, your PC will find OpenSDA debugger and install related driver to make it works.
Wish it helps.
Ma Hui
