You don't give us any details on what you need for measurement details, like level, accuracy, AC(frequency?)/DC, or isolation requirements. Overall, it's not quite clear what help you are looking for --- there are three ways to convert current to voltage, and if you don't want the shunt resistance method then if AC-current a sense-transformer is viable (and isolated, although their effect reflects as a low shunt resistance), or you can go with a Hall-effect IC:
Current Transducers | DigiKey
