I just check the Ultra_bubble_demo_user's_guide.pdf
inside there they use flashloader.bin blhost to erase memory region
flash-erase-region <addr> <byte_count> [memory_id]
Blhost.exe -u -- flash-erase-region 0x80000 0x50000 0x101
Blhost.exe –p COM1, 57600 – flash-erase-region 0x80000 0x50000 0x101
The above example causes the flashloader
to erase 0x50000 Bytes starting at 0x80000 of SPI NAND memory region.
and mentioned SPI NAND starting address is 0x80000, so what is this referring to, is this configurable? and why can't I find this info in K32 datasheet?
