How to develop Smart meter application
1,367件の閲覧回数
arun_bhardwaj21
I am very new for these kind of programming. I am trying to create a Smart meter application. I want to create an application, which will collect data from installed meters, which are located at different locations. And I can create different report. The application can also send signal to meter to on/off the meter.
My Questions: I have work experience in Java for web-development. Just to save time, I want to understand-
From where I should start? which IDE is suitable to develop this app?
Any Mock/simulator, which can be used as a meter?
Which software packages on NXP or anywhere, I should look first?
Any other suggestion or link, which I can refer.
Thanks in advance for your help.
1,319件の閲覧回数
kerryzhou
Hi Arun Bhardwaj
  If you want to design the meter, you can check the kinetis KM series:
Arm® Cortex®-M0+|Kinetis® KM3x 50-75 MHz 32-bit MCUs | NXP
  There some designs for your reference.
  Please check it at first, you will find the related IDE, software.
Kerry
