How to calibrate the dac on KL25z?
933 次查看
royal_agha
is there an automatic calibration function for the DAC? I know there is a calibration function for the ADC where the processor calculates the necessary calibration values. Is there something similar for the DAC? if not what is the best way to calibrate it especially with the non-linear behavior at very low voltage outputs(0.02 volts is the lowest I need )?
标记 (1)
783 次查看
jeremyzhou
Hi Royal,
For the better performance of DAC, I'd like to suggest refer for design as below to improve the bandwidth preformance.
And please place this capacitance as close as the corresponding DACx_OUT pin as possible on the layout.
Hope it helps.
Ping
