High Speed RNDIS and CDC composite (?)
1,207 次查看
mjbcswitzerland
Specialist V
Hi All
I am wondering whether anyone has used RNDIS + CDC composite on a K61 or K70's HS USB interface?
The issue that I have is that I can do this on any FS USB interface since they have 16 endpoints but the K61/K70's HS USB has just 4 and this configuration essentilly needs 5:
- Endpoint 0 - control
- Endpoint 1 - RNDIS bulk IN/OUT
- Endpoint 2 - RNDIS interrupt
- Endpoint 3 - CDC bulk IN/OUT
- Endpoint 4 - CDC interrupt
In fact the CDC interrupt endpoint is not used in practice but I don't know whether there is any way to configure so that it is not needed to satisfy the host or whether there is some other trick to get around this.
Any ideas (without having to move to K66 with 8 HS endpoints)???
Mark
0 回复数
