Help! Warning "failed to initialize pemicro interface dll"
3,398件の閲覧回数
w_x
While using TWR board, I tryed to download code to target in IAR, It showed this message  "failed to initialize pemicro interface dll". What's the problem? Anyone can help?
2,817件の閲覧回数
J2MEJediMaster
Specialist I
You are missing the driver for your run controller/emulator probe. If you are using a P&E Microsystems probe or a Freescale TAP (which amounts to the same thing), you can download the drivers at www.pemicro.com.
---Tom
2,817件の閲覧回数
ahmedrida
Hello, I'm having the same problem using TWR vf65gs10 board, trying to run an example for my board but cant' connect to target. I get the same message or the message :
Target is running. Stop target ? I reset the target put yes and the same message comes.
Anyone can help ?
