Hardfault interrupt while accessing any RTC register of MK22FX512AVLQ12
1,326 次查看
prasannanaik
   I am using MK22FX512AVLQ12 microcontroller. While initializing RTC using RTC_Init(RTC_Type *base, const rtc_config_t *config) function from "fsl_rtc.h" file, my code goes to hardfault interrupt.
   On further debugging i found that the code goes to hardfault interrupt when i try to read/write any RTC register.
   I have attached my code for reference, please help in resolving this query.
Thanks & best regards,
Prasanna
1,239 次查看
ErichStyger
Specialist I
Is your RTC powered by the external Bat/RTC pin? Otherwise it will hardfault.
I hope this helps,
Erich
