Hardfault handler exception
arunkannan
The jumptouserapplication() function is going to hardfault handler in NXP Kinetis Bootloader 2.0.0
Tried debugging but couldnt resolve.
Kindly help
arunkannan
Set the application start address in flash in MCU settings which resolved the issue
arunkannan
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, but I´m following your 3 cases, I will continue this in the internal where you upload some images.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1848716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHardfault%20handler%20exception%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20jumptouserapplication()%20function%20is%20going%20to%20hardfault%20handler%20in%20NXP%20Kinetis%20Bootloader%202.0.0%3C%2FP%3E%3CP%3ETried%20debugging%20but%20couldnt%20resolve.%3C%2FP%3E%3CP%3EKindly%20help%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1848716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKinetis%20L%20Series%20MCUs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Hardfault%20handler%20exception%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESet%20the%20application%20start%20address%20in%20flash%20in%20MCU%20settings%20which%20resolved%20the%20issue%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Hardfault%20handler%20exception%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20my%20name%20is%20Pavel%2C%20and%20I%20will%20be%20supporting%20your%20case%2C%20but%20I%C2%B4m%20following%20your%203%20cases%2C%20I%20will%20continue%20this%20in%20the%20internal%20where%20you%20upload%20some%20images.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
