HEXIWEAR FLEXCAN
HEXIWEAR FLEXCAN
1,232件の閲覧回数
nagaswaroop_hc
HI NXP Team,
I am trying to implement  FlexCAN bus in Hexiwear i am not able to get the example code of that.
Please send the FlexCAN code for TX and RX.
Thanks & Regards
Swaroop
Engineer-Embedded Software
1,118件の閲覧回数
kerryzhou
Hi NAGASWAROOP HC,
    As I know, the HEXIWEAR is using the MK64FN1M0VDC12 chip, this chip have the flexCAN module, so you can use the CAN function.
    You can download the K64 SDK code, the link is:
https://mcuxpresso.nxp.com/en/select
  Select the K64 chip, then generate the code and download it.
  After you download it, you can find the flexCAN code in folder:
SDK_2.2_TWR-K64F120M\boards\twrk64f120m\driver_examples\flexcan
Wish it helps you!
Kerry
