Floating point value
2,429 次查看
chetan98
I'm using Kw45 sdk example, for KW45 board I'd like to print the Floating point accelerometer values to the terminal using shell I also tried.
sprintf(str,"%f");
printf("%s",str);
IDE using MCU expresso
But using printf or sprintf it is not printing even decimal value.
Chetan
2,311 次查看
chetan98
Hello Happy Diwali,
I am using Kw45 wireless uart and I want print value with 3 precision after point.
For eg 300.645
Chetan
2,230 次查看
sofiaurueta
Hello @chetan98 ,
Similarly to the ble_shell example, in the wireless_uart example, values are printed to the terminal using Serial_PrintDec function, which internally calls FORMAT_Dec2Str to convert integers into strings. See fsl_format.c for the conversion process:
/*Convert a uint32 to string*/
uint8_t *FORMAT_Dec2Str(uint32_t num)
Using this function as reference, you could implement a function to convert floating-point values to strings through a division-based method (split the float into its integer and decimal parts, convert each part to a string separately, and then combine them with a decimal point in between).
Ana Sofia.
2,400 次查看
luis_maravilla
Hello Chetan,
Could you help us confirm what example are you using and for which SDK version please?
In the [ble_shell] example from the KW45 SDK, values are printed to the terminal using the function [SHELL_PrintfSynchronization], which is defined in [ble_shell.h].
To print integer values, the SDK uses [shell_writeDec], which internally calls [FORMAT_Dec2Str] to convert integers into strings. This conversion process is implemented in [fsl_format.c].
Using this approach as a reference, you could apply a similar method to convert floating-point values to strings and send to terminal.
Hope this information work for you.
Best Regards
Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%B5%AE%E7%A9%BA%E7%82%B9%E5%80%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Kw45%20sdk%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%AF%B9%E4%BA%8E%20KW45%20%E6%9D%BF%EF%BC%8C%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E7%9A%84%E5%A4%96%E5%A3%B3%E5%B0%86%E6%B5%AE%E7%A9%BA%E7%82%B9%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E7%9A%84%E5%80%BC%E6%89%93%E5%8D%B0%E5%88%B0%E7%BB%88%E7%AB%AF%E3%80%82%3C%2FP%3E%3CP%3Esprintf(str%2C%22%25%20f%22)%EF%BC%9B%3C%2FP%3E%3CP%3Eprintf(%22%25%20s%22%2Cstr)%EF%BC%9B%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20MCU%20expresso%20%E7%9A%84%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%20%3C%2FP%3E%3CP%3E%E4%BD%86%E4%BD%BF%E7%94%A8%20printf%20%E6%88%96%20sprintf%20%E6%97%B6%EF%BC%8C%E7%94%9A%E8%87%B3%E8%BF%9E%E5%8D%81%E8%BF%9B%E5%88%B6%E5%80%BC%E9%83%BD%E6%97%A0%E6%B3%95%E6%89%93%E5%8D%B0%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%88%87%E5%9D%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F249367%22%20target%3D%22_blank%22%3E%40chetan98%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%8E%20ble_shell%20%E7%A4%BA%E4%BE%8B%E7%B1%BB%E4%BC%BC%EF%BC%8C%E5%9C%A8%20wireless_uart%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%95%B0%E5%80%BC%E9%80%9A%E8%BF%87%20Serial_PrintDec%20%E5%87%BD%E6%95%B0%E6%89%93%E5%8D%B0%E5%88%B0%E7%BB%88%E7%AB%AF%EF%BC%8C%E8%AF%A5%E5%87%BD%E6%95%B0%E5%86%85%E9%83%A8%E8%B0%83%E7%94%A8%20FORMAT_Dec2Str%20%E5%B0%86%E6%95%B4%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%E6%9C%89%E5%85%B3%E8%BD%AC%E6%8D%A2%E8%BF%87%E7%A8%8B%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%20fsl_format.c%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%2F*%E5%B0%86%20uint32%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2*%2F%3C%2FP%3E%0A%3CP%3Euint8_t%20*FORMAT_Dec2Str(uint32_t%20num)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%87%BD%E6%95%B0%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%E4%B8%80%E4%B8%AA%E5%87%BD%E6%95%B0%EF%BC%8C%E9%80%9A%E8%BF%87%E5%9F%BA%E4%BA%8E%E9%99%A4%E6%B3%95%E7%9A%84%E6%96%B9%E6%B3%95%E5%B0%86%E6%B5%AE%E7%82%B9%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%88%E5%B0%86%E6%B5%AE%E7%82%B9%E6%95%B0%E5%88%86%E6%88%90%E6%95%B4%E6%95%B0%E5%92%8C%E5%8D%81%E8%BF%9B%E5%88%B6%E9%83%A8%E5%88%86%EF%BC%8C%E5%B0%86%E6%AF%8F%E4%B8%AA%E9%83%A8%E5%88%86%E5%88%86%E5%88%AB%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%AE%83%E4%BB%AC%E4%B8%8E%E4%BB%8B%E4%BA%8E%E4%B8%A4%E8%80%85%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B0%8F%E6%95%B0%E7%82%B9%E5%90%88%E5%B9%B6%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EAna%20Sofia%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%8E%92%E7%81%AF%E8%8A%82%E5%BF%AB%E4%B9%90%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Kw45%20%E6%97%A0%E7%BA%BF%20uart%EF%BC%8C%E6%88%91%E6%83%B3%E5%9C%A8%E7%82%B9%E5%90%8E%E6%89%93%E5%8D%B0%203%20%E4%B8%AA%E7%B2%BE%E5%BA%A6%E7%9A%84%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%20300.645%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%88%87%E5%9D%A6%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%9F%A5%E5%9D%A6%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E6%88%91%E4%BB%AC%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%A4%BA%E4%BE%8B%E4%BB%A5%E5%8F%8A%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20SDK%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20KW45%20SDK%20%E7%9A%84%20%5Bble_shell%5D%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E4%BD%BF%E7%94%A8%20%5Bble_shell.h%5D%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%E5%87%BD%E6%95%B0%20%5BSHELL_PrintfSynchronization%5D%20%E5%B0%86%E6%95%B0%E5%80%BC%E6%89%93%E5%8D%B0%E5%88%B0%E7%BB%88%E7%AB%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E6%89%93%E5%8D%B0%E6%95%B4%E6%95%B0%E5%80%BC%EF%BC%8CSDK%20%E4%BD%BF%E7%94%A8%20%5Bshell_writeDec%5D%20%E5%86%85%E9%83%A8%E8%B0%83%E7%94%A8%20%5BFORMAT_Dec2Str%5D%20%E5%B0%86%E6%95%B4%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%E8%BF%99%E4%B8%80%E8%BD%AC%E6%8D%A2%E8%BF%87%E7%A8%8B%E5%9C%A8%20%5Bfsl_format.c%5D%20%E4%B8%AD%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%BA%94%E7%94%A8%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%96%B9%E6%B3%95%E5%B0%86%E6%B5%AE%E7%82%B9%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%E5%B9%B6%E5%8F%91%E9%80%81%E5%88%B0%E7%BB%88%E7%AB%AF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%AF%B9%E4%BD%A0%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
