Flexbus configuration modified in MCUXpresso IDE v24.12 [Build 148] [2025-01-10]
ChristofAbt
this is an information. Each time if I change something in the Pins perspective and update the code, the following two entries in my flexbus configuration are changed
.byteLaneShift is modified to kFLEXBUS_NotShifted,
and
.portSize is modified to kFLEXBUS_1Byte
It took me a while to find out why my flexbus does not work any more
after having added a pull-up to a pin.
Christof Abt
EdwinHz
Hi @ChristofAbt,
In order to support you better, could you please share the MCU that you are using?
Also, have you had the opportunity to test this on our newest MCUXpresso IDE release (v25.6)?
ChristofAbt
Good morning,
I am using the FRDM-K66F board and the MCOXpresso version
best regards
Christof Abt
EdwinHz
@ChristofAbt,
Thanks for the information, I recommend updating to the latest version of MCUXpresso (v25.6).
Either way, thanks for reporting your findings on the v24.12 release of the IDE.
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2187590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexbus%20configuration%20modified%20in%20MCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Ethis%20is%20an%20information.%20Each%20time%20if%20I%20change%20something%20in%20the%20Pins%20perspective%20and%20update%20the%20code%2C%20the%20following%20two%20entries%20in%20my%20flexbus%20configuration%20are%20changed%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E.byteLaneShift%20is%20modified%20to%20%3C%2FSPAN%3E%3CSPAN%3EkFLEXBUS_NotShifted%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eand%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.portSize%20is%20modified%20to%20%3C%2FSPAN%3E%3CSPAN%3EkFLEXBUS_1Byte%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIt%20took%20me%20a%20while%20to%20find%20out%20why%20my%20flexbus%20does%20not%20work%20any%20more%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eafter%20having%20added%20a%20pull-up%20to%20a%20pin.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EChristof%20Abt%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexbus%20configuration%20modified%20in%20MCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248592%22%20target%3D%22_blank%22%3E%40ChristofAbt%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20information%2C%20I%20recommend%20updating%20to%20the%20latest%20version%20of%20MCUXpresso%3CSPAN%3E%26nbsp%3B(v25.6).%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EEither%20way%2C%20thanks%20for%20reporting%20your%20findings%20on%20the%20v24.12%20release%20of%20the%20IDE.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EEdwin.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexbus%20configuration%20modified%20in%20MCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20morning%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20am%20using%20the%20FRDM-K66F%20board%20and%20the%20MCOXpresso%20version%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EMCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ebest%20regards%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EChristof%20Abt%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexbus%20configuration%20modified%20in%20MCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248592%22%20target%3D%22_blank%22%3E%40ChristofAbt%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EIn%20order%20to%20support%20you%20better%2C%20could%20you%20please%20share%20the%20MCU%20that%20you%20are%20using%3F%3C%2FP%3E%0A%3CP%3EAlso%2C%20have%20you%20had%20the%20opportunity%20to%20test%20this%20on%20our%20newest%20MCUXpresso%20IDE%20release%20(v25.6)%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
