Floating point value
2,500件の閲覧回数
chetan98
I'm using Kw45 sdk example, for KW45 board I'd like to print the Floating point accelerometer values to the terminal using shell I also tried.
sprintf(str,"%f");
printf("%s",str);
IDE using MCU expresso
But using printf or sprintf it is not printing even decimal value.
Chetan
3 返答(返信)
2,382件の閲覧回数
chetan98
Hello Happy Diwali,
I am using Kw45 wireless uart and I want print value with 3 precision after point.
For eg 300.645
Chetan
2,301件の閲覧回数
sofiaurueta
Hello @chetan98 ,
Similarly to the ble_shell example, in the wireless_uart example, values are printed to the terminal using Serial_PrintDec function, which internally calls FORMAT_Dec2Str to convert integers into strings. See fsl_format.c for the conversion process:
/*Convert a uint32 to string*/
uint8_t *FORMAT_Dec2Str(uint32_t num)
Using this function as reference, you could implement a function to convert floating-point values to strings through a division-based method (split the float into its integer and decimal parts, convert each part to a string separately, and then combine them with a decimal point in between).
Ana Sofia.
2,471件の閲覧回数
luis_maravilla
Hello Chetan,
Could you help us confirm what example are you using and for which SDK version please?
In the [ble_shell] example from the KW45 SDK, values are printed to the terminal using the function [SHELL_PrintfSynchronization], which is defined in [ble_shell.h].
To print integer values, the SDK uses [shell_writeDec], which internally calls [FORMAT_Dec2Str] to convert integers into strings. This conversion process is implemented in [fsl_format.c].
Using this approach as a reference, you could apply a similar method to convert floating-point values to strings and send to terminal.
Hope this information work for you.
Best Regards
Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E5%80%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%20Kw45%20SDK%20%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82KW45%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E5%80%A4%E3%82%92%E7%AB%AF%E6%9C%AB%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esprintf(str%2C%22%25f%22)%3B%3C%2FP%3E%3CP%3Eprintf(%22%25s%22%2Cstr)%3B%3C%2FP%3E%3CP%3EMCU%20Expresso%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FIDE%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81printf%20%E3%81%BE%E3%81%9F%E3%81%AF%20sprintf%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%B0%8F%E6%95%B0%E5%80%A4%E3%82%82%E5%8D%B0%E5%88%B7%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%82%BF%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2187694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F249367%22%20target%3D%22_blank%22%3E%40chetan98%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eble_shell%20%E3%81%AE%E4%BE%8B%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81wireless_uart%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81Serial_PrintDec%20%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%80%A4%E3%81%8C%E7%AB%AF%E6%9C%AB%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E5%86%85%E9%83%A8%E3%81%A7%20FORMAT_Dec2Str%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E6%95%B4%E6%95%B0%E3%82%92%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%8F%9B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81fsl_format.c%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%2F*uint32%E3%82%92%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B*%2F%3C%2FP%3E%0A%3CP%3Euint8_t%20*FORMAT_Dec2Str(uint32_t%20%E6%95%B0%E5%80%A4)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%99%A4%E7%AE%97%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E6%96%B9%E6%B3%95%20(%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%95%B0%E3%82%92%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E3%81%A8%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E5%89%B2%E3%81%97%E3%80%81%E5%90%84%E9%83%A8%E5%88%86%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E9%96%93%E3%81%AB%E5%B0%8F%E6%95%B0%E7%82%B9%E3%82%92%E5%85%A5%E3%82%8C%E3%81%A6%E7%B5%90%E5%90%88%E3%81%99%E3%82%8B)%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E5%80%A4%E3%82%92%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%A2%E3%83%8A%E3%83%BB%E3%82%BD%E3%83%95%E3%82%A3%E3%82%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%83%E3%83%94%E3%83%BC%E3%83%87%E3%82%A3%E3%83%AF%E3%83%AA%3C%2FP%3E%3CP%3EKw45%20%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%20UART%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E5%BE%8C%E3%81%AB%203%20%E7%B2%BE%E5%BA%A6%E3%81%A7%E5%80%A4%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0300.645%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%82%BF%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Floating%20point%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%82%A7%E3%82%BF%E3%83%B3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BE%8B%E3%82%92%E3%81%A9%E3%81%AE%20SDK%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EKW45%20SDK%20%E3%81%AE%20%5Bble_shell%5D%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%5Bble_shell.h%5D%20%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%96%A2%E6%95%B0%20%5BSHELL_PrintfSynchronization%5D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%80%A4%E3%81%8C%E7%AB%AF%E6%9C%AB%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%B4%E6%95%B0%E5%80%A4%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81SDK%20%E3%81%AF%20%5Bshell_writeDec%5D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%20%5BFORMAT_Dec2Str%5D%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E6%95%B4%E6%95%B0%E3%82%92%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%8F%9B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%5Bfsl_format.c%5D%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E5%80%A4%E3%82%92%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E7%AB%AF%E6%9C%AB%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
