Flash read write example for MKE04Z8VTG4
4,812 次查看
okaner
       I am using MKE04Z microcontroller and SDK(SDK_2.9.0_MKE04Z8xxx4) . Is there any example how to use fsl_flash.c for this sdk. I saw pflash.c for the other microcontrollers but I think they use different sdk with different functions and parameters. Thank you.
Okan,
4,799 次查看
Anonymous
不适用
hai okaner,
  I also having same issue but in the SDK Builder itself shows "The SDK does not include FRDM-KE04Z board project examples for MCUXpresso IDE" . So i refer MKE02 MCU for my reference and examples.
Kalaimani Arumugam
4 回复数
4,800 次查看
Anonymous
不适用
hai okaner,
Kalaimani Arumugam
4,797 次查看
okaner
Hi Kalaimani,
      I found examples for MKE02. Thank you very much.
Okan,
4,806 次查看
kerryzhou
Hi okaner,
  Can't you find the pflash demo from this link:
SDK_2.9.0_FRDM-KE04Z\boards\frdmke04z\driver_examples\flash\pflash
At lease, in the SDK 2.8.0, I still can find the pflash project, please check your SDK folder, whether you have that project or not?
If you still have issues about it, please kindly let me know.
Kerry
4,803 次查看
okaner
Hi Kerry,
     I have only uart example for both versions of SDK. In SDK Builder application, if I select filter for pflash.c example, in next step I cannot select Kinetis E series.
