Flash read write example for MKE04Z8VTG4
4,768件の閲覧回数
okaner
       I am using MKE04Z microcontroller and SDK(SDK_2.9.0_MKE04Z8xxx4) . Is there any example how to use fsl_flash.c for this sdk. I saw pflash.c for the other microcontrollers but I think they use different sdk with different functions and parameters. Thank you.
Okan,
4,755件の閲覧回数
Anonymous
適用対象外
hai okaner,
  I also having same issue but in the SDK Builder itself shows "The SDK does not include FRDM-KE04Z board project examples for MCUXpresso IDE" . So i refer MKE02 MCU for my reference and examples.
Kalaimani Arumugam
4 返答(返信)
4,756件の閲覧回数
Anonymous
適用対象外
hai okaner,
Kalaimani Arumugam
4,753件の閲覧回数
okaner
Hi Kalaimani,
      I found examples for MKE02. Thank you very much.
Okan,
4,762件の閲覧回数
kerryzhou
Hi okaner,
  Can't you find the pflash demo from this link:
SDK_2.9.0_FRDM-KE04Z\boards\frdmke04z\driver_examples\flash\pflash
At lease, in the SDK 2.8.0, I still can find the pflash project, please check your SDK folder, whether you have that project or not?
If you still have issues about it, please kindly let me know.
Kerry
4,759件の閲覧回数
okaner
Hi Kerry,
     I have only uart example for both versions of SDK. In SDK Builder application, if I select filter for pflash.c example, in next step I cannot select Kinetis E series.
