Flash operration
Flash operration
2,235件の閲覧回数
kalaimaniarumug
How to calculate the FLASH writing time of MKV3x serious microcontroller? The formula for that. Why is it not working in high speed mode?
2 返答(返信)
2,167件の閲覧回数
mjbcswitzerland
Specialist V
Flash write times can be found in the data sheet. However they vary between chips and change with age and so can not be considered to be a fixed value - instead you need to consider the maximum value that is given.
In HSRUN mode flash operations are not possible - they are blocked. I don't know the physical reasons for this.
Mark
[uTasker project developer for Kinetis and i.MX RT]
2,167件の閲覧回数
bobpaddock
Senior Contributor III
Some Flash technologies are slow compared to the reset of a given architecture, so various work arounds are implemented, copy to RAM and run from there, wait states, don't allow  etc.
https://www.renesas.com/us/en/  Rx parts have a faster Flash technology than most other implementations, so don't run into until a lot higher frequencies.
