FRDM-KW41Z
FRDM-KW41Z
surender1896
How to read multiple ADC channel values on FRDM-KW41Z, can anyone post the example or code for it
Sebastian_Del_Rio
Hello Sureneder, I hope you’re doing well!
The ADC examples are included in the SDK that you can download from our online SDK builder.
When the SDK is downloaded and installed, you can access the examples from the Quickstart panel in MCUXpresso, by clicking on the "Import SDK example(s)…".
On the screen that opens, you can select your board, and then you'll find a list with all the examples for the board you chose, and there you will find our ADC examples, as well as other useful examples.
I hope this helps you.
Sebastian
Sebastian_Del_Rio
Sebastian
surender1896
Thank you sebastian
