FRDM-KL43Z pinout
FRDM-KL43Z pinout
1,800 次查看
benjamin_miller
Does anyone know where I can find excel sheet for the FRDM-KL43Z pinout? It is referenced in the KL43Z user guide, but I cannot seem to find the actual excel document with pinout details.
1,629 次查看
FelipeGarcia
Hi Benjamin,
You can take the "Kinetis KL43 Microcontroller" datasheet as reference in chapter 5 "Pinouts and Packaging".
https://www.nxp.com/docs/en/data-sheet/KL43P64M48SF6.pdf
Also, if you are using the FRDM-KL43Z SDK you can find the pinout if you go to ConfigTools -> Pins in MCUXpresso.
Felipe.
