FRDM_KL25Z problem
FRDM_KL25Z problem
mato_cica1
I have started some demo applications from SDK for FRDM_KL25Z. when I run demo for UART I can not fire LED diodes, and when I started LED demo I can not start UART in that application. What should I do to get UART functionalities in LED application and vice versa?
Thank you,
kerryzhou
Hi Mato Cica
    This question is duplicated with your case, now just add the case answer:
Thank you for your interest in the NXP kinetis product, I would like to provide service for you.
Do you configure the correct code?
Especially the pins, please check the pinmux.c, and refer to the SDK code to add it.
Then try it again.
Your problem is mainly caused by your code, please refer to the SDK code carefully.
If you still have questions about it, please kindly let me know.
If your question is solved, please tell me to close this case, and help to me fill the feedback as resolved, thank you!
Kerry
kerryzhou
Hi Mato Cica
Then try it again.
Kerry
