External RAM on KL25Z
jairo15
I need help to interface an external RAM in KL25Z.
I need to build a buffer with 64kB.
Can anyone help me?
Thanks.
Monica
Senior Contributor III
Hello Jairo,
How is the project going, did this solved your questions?
Please let us know :smileywink:
Monica
jairo15
Hi Monica,
My project is summarized in a speech delay, with the internal memory has managed to make it work for 1 sec.
I need more time, nearly 5 seconds I think to use RAM SPI 23LC1024 to do this, but I have not found in the local market, so I can report the results.
Paul_Tian
As you know, KL series product has not Flex bus, so it is not suitable to do your application. We recommend Kinetis K series product for you. If you have to use KL25, I think it depends on which function you need. If you need to store data temporary, I think you can use GPIO to simulate. If code, KL25 cannot use in this way.
