Execute command not jumping to LED blink application
arunkannan
We have the LED blink application at 0x9000 and when we run execute command in blhost as below it is not going to application and LED is not blinking.
C:\blhost\win>blhost.exe -p COM4,115200 execute 0x9000 0 0x20002f80
Ping responded in 1 attempt(s)
Inject command 'execute'
Successful generic response to command 'execute'
Response status = 0 (0x0) Success.
Kindly let me know how to make it jump to 0x9000 to make LED blink
Pavel_Hernandez
Hello, could you elaborate further on your issue? is not enough to analyze your behavior. What kind of IDE are you using and what is your target MCU? Are you using an EVK or custom board?
Is this HardFualt happening on an example SDK? Could you share the name of the project or the project to replay the issue and the steps?
Pavel
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, but I´m following your 3 cases, I will continue this in the internal where you upload some images.
Pavel
arunkannan
You can close other cases. Resolved those issues. Need help on this one alone.
