Error: unable to open CMSIS-DAP device
ソリューションへジャンプ
4,485件の閲覧回数
mohammadgouse
I purchased FRDM-K82 kit and start to test it using Kinetis design studio 3.0 in windows 10. while trying to debug with the kit i am getting following error.
Open On-Chip Debugger 0.8.0-dev (2015-01-09-16:22)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'cmsis-dap'
Error: unable to init CMSIS-DAP driver
Error: Error selecting 'cmsis-dap' as transport
Runtime Error: C:/Freescale/KDS_v3/openocd/bin/..//scripts/kinetis.cfg:3:
in procedure 'script'
at file "embedded:startup.tcl", line 58
in procedure 'interface' called at file "C:/Freescale/KDS_v3/openocd/bin/..//scripts/kinetis.cfg", line 3
I tried this windows 8 OS also, the result is,
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
localhost:3333: The system tried to join a drive to a directory on a joined drive.
ラベル(2)
3,236件の閲覧回数
Hui_Ma
I would recommend customer to update FRDM-K82 board OpenSDA firmware to J-Link.
Customer could find and download Segger J-Link firmware from here.
Please let us know if there still with issues after update with J-Link firmware.
Wish it helps.
Ma Hui
3,237件の閲覧回数
Hui_Ma
Wish it helps.
Ma Hui
