Error: Cannot access device, device is secured
2,520 次查看
earivas
Good morning, I am try to program a MK222FN512 microcontroller mounted on a PCB by means of the OpenSDA interface of a FRDM-K22F development platform.
I have been using this microcontroller with no problems, but suddenly a debug session froze and when restarting, I am not able to debug again, and I always get the error in the title. I am using the GDB OpenOCD Debugging configuration, and I found no way to do a mass erase.
Additionally, I have succesfully rebooted the microcontroller using BOOTLOADER file k20dx128_bootloader_v21_0x8000.bin, but I always get the same error message when trying to debug.
Is there any way I can do a hard reset of the flash memory?
Thanks and best regards!
4 回复数
2,392 次查看
Hui_Ma
Please refer below thread about how to unlock Kinetis chip:
https://community.nxp.com/thread/439921?commentID=857127#comment-857127
Ma Hui
2,392 次查看
earivas
thanks for your kind response.
I had already checked that thread, but the problem is that I am programming the micro via OpenOCD through the SWD connection, I am not using J-link programmer...
Regards.
2,392 次查看
Hui_Ma
Unfortunately, we don't have the Open OCD debugger tool.
Could you check with the OpenOCD ? If any engineer has experience to use OpenOCD unlock Kinetis chip.
Thanks.
best regards,
Mike
2,392 次查看
earivas
Will try. Thanks anyway.
