Enob calculation for SD ADC. Accuracy against conversion time
2,679件の閲覧回数
stanpodlisker
I'd like to evaluate the MKMxxZxxCxx5 for high accuracy of my  measurement. So my questions are:  1. How to calculate the ENOB for their integrated SD  ADC.What the dependency between ENOB,Sampling clock,and  OSR. I need to estimate the design to conversion time against  accuracy because the conversion time may be critical.   2. I need also to understand the SINAD and CMMR for  Bandwidth up to 10 kHz of differential Analog inputs   3. Is the any DMA channel works with SD ADC
2,290件の閲覧回数
jeremyzhou
Hi Stan,
Sure, ADC can work with DMA.About your other question, I think you'd better to reference the datasheet.
I attach a application document that introduce how to configure ADC work with DMA and datasheet of K60.
Wish these can help you.
Ping
