How to read out s-record (s19) from KL04?
ソリューションへジャンプ
2,494件の閲覧回数
kelvin_wh
Hi all,
Anyone know how to read out the s-record from KL04? I'm using multilink and codewarrior.
Any help much appreciate.
Thanks.
Kelvin
2,383件の閲覧回数
BlackNight
4 返答(返信)
2,384件の閲覧回数
BlackNight
Hi Kelvin,
have a look here:
Dump my Device Memory | MCU on Eclipse
2,383件の閲覧回数
kelvin_wh
Hi Erich,
Thanks. That's reading out the memory when developing? How about reading out s-record from a working IC or a failed IC?
Kelvin
2,383件の閲覧回数
BlackNight
You can do this while debugging (developing your own program).
But you can do this as well as long you have a connection to the device. Simply attach/connect to it (see Hot-Sync: Attach, Connect & Download | MCU on Eclipse).
But of course if you do not have a working connection to the device, or if the device is secured and you cannot access the memory, you cannot read out the content of it ;-).
2,383件の閲覧回数
kelvin_wh
Thanks Erich!
