Endianess in ARM Cortex M0+ MCUs
carloscuev
Contributor V
Hello, I'm working with a KL25 Freedom board. I would like to know how to change the endianess to big endian, by default it is configured with little endian. I don't know if this optimized cortex still has the option to select endianess as other ARM cores do. I found the option in CW v10.4 but is not selectable. Does anyone know if it's possible?
Labels (2)
ZhangJennie
for kinetis, CW support big endian only. see Erich blog documented on this topic:
http://mcuoneclipse.com/2012/02/19/a-little-or-big-indian-a-plea-for-peace/
