Embedded Trace Macrocell (ETM) PCB Routing Tips
2,973 次查看
pgvoorhees
Hello Community,
We are planning on using ETM to aid in debugging but have found very few routing guidelines for the TRACE_D[0:3] and TRACE_CLK nets.
On the K22FX512, using a 120MHz core speed, What is:
  • The clock speed of the TRACE nets? Datasheet says the interface is limited to 50MHz but offers no guidance for determining the speed.
  • Is any particular characteristic impedance for the traces necessary?
  • Do the lines need to be length-matched?
Design guild-lines seem to be largely unavailable and the Kinetis datasheets are light on details for this particular functionality. Any help is appreciated. Thanks!
2,649 次查看
pgvoorhees
The best reference I've found for this is the Segger J-Link/J-Trace manual.
J-Link Debug Probes | SEGGER - The Embedded Experts
Chapter 17 (as of this post) called "Designing the target board for trace"
