ECC algorithm used by the Nand Controller (NFC) in the Kinetis series processors?
1,292 次查看
yslavcom
Hello, I need to implement in software the ECC algorithm  which is used by the Nand Controller (NFC) in the Kinetis series processors. Reference Manual says it is based on BCH, but I need more details in order to be able to realize it for simulation/test software, i.e. what is the GF(x), is it Reed-Solomon (a subset of BCH), etc
Does anybody know it?
Thank you
1,119 次查看
Kan_Li
The NFC ECC algorithm is BCH, not RS.
GF(x) is Galois field.
BCH code is defined over the Galois field.
Hope that makes sense,
Kan
