Does flash swap work on chips with FlexNVM?
1,837 次查看
c_johnson
The NXP documentation talks about flash swap not working on chips that have FlexNVM "Enabled".  As far as I can tell you can not disable FlexNVM.  Does this mean that if you want to use flash swapping that you must use a chip that has only program flash?
I am specifically wondering if it is possible to do flash swapping for firmware update on a MK66FX1M0VLQ18 chip.
Chris
标记 (1)
1,776 次查看
jingpan
No, it is impossible. Please see the reference manual section 4.2
For the devices containing program flash and FlexNVM:
• The program flash swap feature is not available.
Jing
