Disable SWD pins
Disable SWD pins
1,838 次查看
razumovskyeduar
Hello
Can we disable the SWD pins (After Boot) ?
If so, will it be a problem connecting again with the debugger ?
The goal is to minimize current consumption....
Edi
1,704 次查看
BlackNight
Hi Edi,
yes, it will be a problem to connect with the debugger after you have disabled the pins.
What I do is this: I wait some time after boot (say 2-5 seconds) until I disable the SWD pins. This gives me time after reset to connect to the board with the debugger.
I hope this helps,
Erich
