Digging into SD host controller on MK20DN512VLQ10
3,282件の閲覧回数
garylynch
I am doing maintenance on a product based on the MK20DN512VLQ10 and am having trouble understanding the data sent to the peripheral registers of its SD host controller.  I contacted the help desk yesterday, asking for the reference manual.  Downloaded suggested document from:
- https://www.nxp.com/docs/en/data-sheet/K20P144M100SF2V2.pdf
When I search it for SDHC, I find a chapter with some timing diagrams and a table of the pins where the signals emerge.  No mention of peripheral registers whatsoever.
I have previously used reference manuals for K60, K10, and K70 processors and they all contained full disclosure for all peripherals. Why can't I find it here?
Advanced thanks for your suggestions.
3,225件の閲覧回数
garylynch
Thanks, Mark.  Your feedback is spot-on, as usual.
So I was correct in asking for the Reference Manual, but should have paid more attention to the first page as the data sheet is so similar.
3,225件の閲覧回数
mjbcswitzerland
Specialist V
Hi Gary
You have a link to the data sheet and not the reference manual.
You can get the K20 100MHz parts' reference manuals at
Arm Cortex-M4|Kinetis K20 100 MHz 32-bit USB MCUs | NXP
Mark
[uTasker project developer for Kinetis and i.MX RT]
3,226件の閲覧回数
garylynch
