Differential Input and Output voltage of DDR and USB Controller of MK70FN1M0VMJ12
1,110件の閲覧回数
puspamnayak
Greetings for the day
Request you to let me know about  the exact values of Differential input volatge VID (min, max) and Differential output voltage VOD (min, max) of DDR signals and USB signals of part no. MK70FN1M0VMJ12
Kindly reply ASAP
Thanks in advance
Best Regards
Puspam Nayak
タグ(1)
979件の閲覧回数
Kan_Li
Hi PUSPAM NAYAK,
DDR controller are compliant to DDR2 SDRAM spec, and USB controller are compliant to USB 2.0 spec, so you may find data from www.jedec.org and www.usb.org.
Hope that helps,
Kan
979件の閲覧回数
puspamnayak
Hi Kan,
Thanks for the information. I will refer the same
Warm regards,
Puspam
