MK60FN1M0VLQ15 material 3N96B and 5N96B have different versions, and the current network port pin does not work. It is OK to replace them with 3N96B. Please help and support me to see the differences between the two versions and see how to modify them. Thank you!
 vicentegomez
			vicentegomez
		The only difference is that mask set 5N96B and mask set 3N96B has different errata sheet, but you can find both errata sheets on the next link
I hope this will help you.
 vicentegomez
			vicentegomez
		You can check if you have any data on the ethernet pins, please check that you do not have any manufacture problem, like open pin, solder short, missing part, wrong part.
All the other functions are working?
 vicentegomez
			vicentegomez
		the only differences are the mask set. Only the errata are different
