Debugger PE Micro connection error for S32K396
2,676 次查看
Silvano
I have this error when I try to debug the S32K396-LQFP-DC :
Silvano_0-1709134668919.pngSilvano_0-1709134668919.pngSilvano_1-1709134700046.pngSilvano_1-1709134700046.png
This is how I connect the board :
Could you help me please ?
Thank you.
标记 (1)
2,602 次查看
lukaszadrapa
LQFP is supported in RTD 4.0.0. You should see this version in the Standard Software package:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-STDSW-D
Lukas
4 回复数
2,640 次查看
Silvano
I finally succeed to communicate with the board, thank you. I have a last question, where can I find the coorect package for the S32K396-LQFP-DC ? Because I have only package for the S32K396_289bga-BGA 289 package. So when I try to compute the code example " Blinking led" , I can not see the led blinking.
Silvano_0-1709307654651.pngSilvano_0-1709307654651.pngSilvano_1-1709307943339.pngSilvano_1-1709307943339.png
2,603 次查看
lukaszadrapa
Lukas
2,645 次查看
Silvano
Hi @lukaszadrapa
Where may I find the schematic that you use in your message ? I have the spf-54614_a.pdf version.
Also, which jumper configuration do you suggest for in-built OpenSDA interface ?
2,651 次查看
lukaszadrapa
Hi @Silvano
if you use in-built OpenSDA interface, you need to select it by jumpers. I can see that ARM connector is selected now:
Regards.
Lukas
