Connect SWD_CLK and SWD_RESET for 4 KL05
4,705 次查看
javierhernande1
I have 4 KL05 in a board, Can I connect the SWD_CLK and RESET pins of the 4 mcus?
4,551 次查看
kerryzhou
Hi Javier Hernandez,
   No, you can connect SWD_DIO and RESET together, but not the SWD_CLK, each chip should have the independent SWD_CLK, otherwise, you can't program it.
Kerry
4 回复数
4,551 次查看
javierhernande1
Better if is possible for common SWD_DIO and RESET because so I can reduce the BOM.
If possible, that would be ideal.
4,552 次查看
kerryzhou
Kerry
4,551 次查看
javierhernande1
Thank you
I have common RESET and SWD_DIO  pins in the 10pos. pin socket. and the 4 pads in the center of the board are the 4 SWD_CLK, one for each mcu.
4,551 次查看
kerryzhou
You are welcome!
 This design is OK to debug for each MCU.
Kerry
