Chip scale package with no bumps
1,433 次查看
davidmichaeli
hello, is it possible to order a WLCSP packaged ic (for example the MK22FN512CBP12R) Without the solder bumps. I'm aware recalling and de balling is a possibility for larger pitched components but here the pitch is too small to handle.
Thanks, david
1,286 次查看
vicentegomez
Please check the package your way for Kinetis MCUs​
Vicente Gomez
