Can the FTM generate the trapezoidal wave?
1,975 次查看
kiyoshimatsuzak
Hi , all.
I made the custom board with the Kinetis K64F.
I try to control some motors via the custom board.
So I have a question.
Can the FTM generate the trapezoidal wave instead of square wave?
If possible, please teach me how to control the FTM.
Kiyoshi Matsuzaki
1,881 次查看
Hui_Ma
The FTM module could only generate square wave.
The K64 product provides DAC module, which could be used to generate the trapezoidal wave.
Wish it helps.
Ma Hui
1,882 次查看
Hui_Ma
Wish it helps.
Ma Hui
1,881 次查看
kiyoshimatsuzak
Hi, Ma
Thank you for your quick reply!
I'll try your info.
Thank you!
Kiyoshi Matsuzaki
