The AN5280(Using Kinetis FlexIO to drive a graphical LCD) chapter 5 shows FlexIO_LCD bus bandwidth performance.
If there couldn't using 16-bit data port to access SDRAM, the FlexIO_LCD maximum bus bandwidth from SDRAM should below 31MBytes/s.
I don't know the LCD display pixel clock frequency (MHz), you could check with LCD display datasheet to get that data.
Please calculate if the FlexIO_LCD bus bandwidth could match with that LCD display requirement.
Wish it helps.
Mike
